LMA's
My b16a hatch is having alittle bit of a prob right now. At right around 3k rpms there is a pretty loud noise comming from my head. before that there is nothing same as after. Now i have been reading up alot on it and i cant find to much about them. But what i have found out on Lost motion assembly is that Type R ones go for right around 30 dollars a piece and theres 8 :o . From reading up on Honda-tech.com i found that Omniman uses this : (2000 prelude vtec LMA's are far less exspensive but you will have to use a .040in thick washer under them. they are just as stiff as the ITR LMA's but only cost about 8-9 dollars. i have them in my car and have run them in many engines that i have built with no problems! they look like tear drop shaped valve springs )
All my valves are fine everything is working good but i just need to get that damn noise out of there.
Its pretty much a bone stock b16a, stock cams and all. The valves are adjusted just right, and like i said its only at 3k. I would think valves would clatter all the way though the RPM band.
Guest
Posts: n/a
1'd l1k3 70 l1573|\| 70 7h15 |\|0153. 7yp1c4lly 1f 7h3 LM4'5 4|23 \^/0|2|\|, 7h3y m4k3 7h3 50u|\|d 47 1dl3. 7h3 c0|\|d1710|\|5 y0u 4|23 d35c|21b1|\|g p01|\|7 70 4|\| 03M 3><h m4|\|1f0ld p|20bl3m \^/h3|23 7h3 \^/3ld5 b|234k 1|\|73|2|\|4lly, c4u51|\|g 7h3 1|\||\|3|2 7ub35 70 |2477l3 47 4|20u|\|d 2800-3200|2pm.
1'd 4l50 b3 v3|2y h35174|\|7 70 u53 4 5h0|273|2 LM4. 3v3|\| 1f y0u u53 4 5p4c3|2, y0u c0mp|21m153 7h3 4v41l4bl3 7|24v3l 0f 7h3 lm4. 1f y0u'|23 g0|\||\|4 b3 pl4y1|\|g 4|20u|\|d 1|\| 3><p3|\|51v3 cyl1|\|d3|2 h34d5, 3><p3c7 70 p4y f0|2 3><p3|\|51v3 p4|275. 13 d0 17 |21gh7 7h3 f1|257 71m3 50 y0u d0|\|7 h4v3 70 d0 17 4g41|\|
Originally posted by Vapor
I'd like to listen to this noise. Typically if the LMA's are worn, they make the sound at idle. The conditions you are describing point to an OEM exh manifold problem where the welds break internally, causing the inner tubes to rattle at around 2800-3200rpm.
I'd also be very hesitant to use a shorter LMA. Even if you use a spacer, you comprimise the available travel of the lma. If you're gonna be playing around in expensive cylinder heads, expect to pay for expensive parts. ie do it right the first time so you dont have to do it again
good luck
Originally posted by StreetDriven
but could you hear it from inside your car? mine is pretty damn loud.
this sounds like a problem that im having with my gsr, its the loudest fuckin noise between 3k & 4k, i dont have stock headers and i took off the heat shields around the header and cat and exhaust. anybody have any ideas?
Actually the prelude LMA's can support cams with up to 12.7mm of lift. I'm interested in trying this too. Also from a reliable source I've been told that the 00 civic si's LmA's perform identicle to ITR ones. The only difference is in the part number and lack of a blue dot. I picked up several sets of 00 si lma's for around $40 a while ago used so that may be a good alternative.
Gracie Barra Clearwater
