Questions about possible swap
Old Sep 17, 2003 | 07:40 PM
GOTTI's Avatar
OEM Parts Specialist
Default Questions about possible swap
Thinking of doing a LS instead of rebuilding the SOHC. What exactly is needed to put a 97 LS motor into my 93 Si.
thanks
Old Sep 17, 2003 | 08:01 PM
GOTTI's Avatar
What axles will i need...is an Auto LS motor going to be ok ina 5 speed?
Old Sep 17, 2003 | 08:13 PM
RaIn.'s Avatar
You need any b series axels(Intermedita shaft too), shift linkage, and yes the Auto motor will be ok as long as of course you have a manual B series tranny to bolt to the longblock, and make sure you use your wiring harness. I'm pretty sure the auto harness will not work.
Old Sep 18, 2003 | 06:31 AM
GOTTI's Avatar
is there any difference in the internals of an auto LS and 5 speed LS..just wondering...if the actual motors are the same
Old Sep 18, 2003 | 10:10 AM
GOTTI's Avatar
what ecu will i need...it has a OBD 2 ecu...and my car has a p28.
Old Sep 18, 2003 | 01:44 PM
GOTTI's Avatar
