Questions about possible swap
Old Sep 19, 2003 | 09:00 PM
GOTTI's Avatar
OEM Parts Specialist
ecu? also i thought you could use the civic mounts?? i need teg mounts..all of them?
Old Sep 20, 2003 | 03:34 AM
2qk4u's Avatar
i think 94-95 LS are obd1 its a p74 or p75 i cant remember
dont u also need obd1 dizzy and injectors?
Old Sep 20, 2003 | 12:52 PM
GOTTI's Avatar
would you use the injectors, alternator and stuff from teh d16 motor?
Old Sep 21, 2003 | 07:50 AM
GOTTI's Avatar
ok i found out i use my injectors..but what about the alternator?
Old Sep 22, 2003 | 04:46 PM
RyanCivic2000's Avatar
Fuck the DOHC
Default Re: Questions about possible swap
Originally posted by 93CivicSiSOHC
Thinking of doing a LS instead of rebuilding the SOHC. What exactly is needed to put a 97 LS motor into my 93 Si.
thanks
Rebuild the D16. If you're going to swap, save the money and get a B18C1.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Sep 22, 2003 | 06:37 PM
  #17 (permalink)
60-1EK's Avatar
Engineer at the source
No, you can use the OBD2 Ls distr and the Ls injectors. The plugs will need to be repinned.
JESUS SAVES
9.69@151 Street Car
JKOBD
