View Poll Results: ls b-18 turbo or ls b-18 vtec turbo
The cost...
60.00%
Bennifits...
20.00%
Cons...
20.00%
overall Opinions...
60.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
LS B-18 turbo or LS B-18 V-tec Turbo???
Old Sep 6, 2003 | 05:04 PM
Jus Skott's Avatar
.arrow Jus Skott
Question LS B-18 turbo or LS B-18 V-tec Turbo???
which is better to run w/??? a ls turbo or a ls vetec turbo????? whats the pros and cons of each??? as well as the cost effectiveness???
Old Sep 6, 2003 | 07:49 PM
99B16Si's Avatar
vtec heads flow better, rev higher, and use more agressive cams which will be better for anything. so i thik the answer is pretty obvious on this one
Old Sep 6, 2003 | 11:40 PM
craig_302's Avatar
boostmonkey
Why would you want a more agressive cam with a turbo motor? GSR cams are about as "wild" as most folks get.
Old Sep 7, 2003 | 12:08 AM
qitstrn's Avatar
Can you spot me 20 cars?
Whats Vtech?
Old Sep 7, 2003 | 07:36 AM
Jus Skott's Avatar
.arrow Jus Skott
The reason for my pol is this right here I currently have a B-18 that I want to work out.... No playing around, none of this little Bolt on and I think I have a race car mentality... (VTEC= Variable timing electronic control) At once time I was thinking about biulding an all motor ls block, but then came the whole turbo and turbo vtec idea..... Truth to be told I still think I would have an all motor, but just trying to get more of an inderstanding..... ya know.... From the looks and other things I have read the only things i can see about a turbo is you get 55 horses ruffly, a kool pppsssstttttt sound and you intimadate people left and right... This also kinda serves as a dual thing a friend io know is thinking along the same lines.... ut I am just starting to think about getting some good heads and werking it out from there....
TR Wondering WTH I moved from FL Member.
Back Then: A stupid Question was one that wasn't asked.
Today: A stupid question is one that wasn't Googled / Ixquicked first.
Old Sep 7, 2003 | 10:15 AM
99B16Si's Avatar
yea 55whp on like 4psi. if the motor has at least aftermarket pistons it will hold at least 12psi tuned with no problem, and will easily make 300whp on that boost level
Old Sep 7, 2003 | 11:14 AM
Sunrise City Rider's Avatar
WHAT!?! OK!......
You ever look at the cams for the Mitsubishi 4g63, Toyota 2jzgte/3sgte, Subaru EJ20, Nissan SR20det/RB26dett?
They all boast high lift and duration as much as 272degrees...This sounds like some sick ass N/A cams for a Honda...
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Sep 7, 2003 | 04:02 PM
Jus Skott's Avatar
.arrow Jus Skott
So are you saying that the OEM Sleeves can handle 15 pnds of boost or am I just on that short bus again... LOL... beep beep... LOL....
