Tech: D series Rebuild...
Guest
Posts: n/a
Evening everyone. Let me start this off by saying I've never rebuilt an engine by myself. Im also not a great writer or any sort of literate person.
So I got a block finally, basicly for free... as most of you know an unfortunate smelting accident blew 3 holes in my last block, and by fire I'm going to do it again. Especially since I got the block so cheap
Ive started by pulling off the oil pan, and removing the main cap (I think that's what it's called.
) I could tell someone had already been in the motor, because the block is mostly bare, and the cap bolts were almost completly lose... so I didn't bother removing them in the proper torque sequence...
There was no oil screen pickup thinggy... so I didn't have to even mess with that. Now the main cap wouldn't just come right off, I had to call a buddy and ask him about this, cause I was pretty stumped on how to get it out... so I had to tap it with a piece of wood and a hammer
, I didn't have a rubber mallet.
I also have a horrible working environment so I put the maincap in a plastic bag to at least help from getting it and the bearings, which I'll probably replace anyhow, from getting dirty.
Once removed I checked the journals on the bottom side of the crank, everything apears very nice, and there are no nicks at all.
I'll post some pics up once I get to work tomorrow. I'll keep updating this as I go along...
PS. If anyone who has expierence with rebuilding Honda motors has insight, or helpful tips, I'd more then like to hear them.
So post up!!
Till tomorrow.
So post up!!
Till tomorrow.
finally cronic, its like defibbing a dead body, i think you have a pulse brutha. lets get the single cammer runnin.
need anything just ask
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Let me know if you need any pointers or tools. I've setup a couple of jigs for plastigauging cranks and seperating rods.
Gracie Barra Clearwater
let me know if you need any parts..i just bought brand new PM6 (D16a6 pistons and rings .25 over) and complete Honda OEM gasket kit , waer pump and head gasket ....i got another setp so i don't need these...let me know if you want em
welcome to my world.
i finally ordered all the gaskets, pumps, seals, etc. to finish putting this motor together. by my bday i will playing with a newly rebuilt by angela and david d series engine in my hatch. wheee!!! then i can work on that suspension problem
just wait until you have to measure and put the piston rings back on. turning those rings to their proper position is a pain but it is really cool to do. then when you put the pistons back in and connect them, the main cap gets in the freakin way and you usually have to start over cuz a bearing got out of place. david found some trick to stop this but i can't remember what is was.
'njoy
i finally ordered all the gaskets, pumps, seals, etc. to finish putting this motor together. by my bday i will playing with a newly rebuilt by angela and david d series engine in my hatch. wheee!!! then i can work on that suspension problem just wait until you have to measure and put the piston rings back on. turning those rings to their proper position is a pain but it is really cool to do. then when you put the pistons back in and connect them, the main cap gets in the freakin way and you usually have to start over cuz a bearing got out of place. david found some trick to stop this but i can't remember what is was.
'njoy
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
well I just got done rebuilding my wifes D15 and I have built a fair amount of engines so If I can help or if you have anyquestions let me know and jeff you know i have the hook up on parts aftermarket and OEM so let me know if there is anything you need man also I have some extra blocks,pistons,heads,crank's,oil pan's,yada,yada,yada....a honda engine can be torn down and rebuilt with in a day with out even removing the block...witch is why i love honda!!!!LOL
let me know if i can help man
art
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
