What is the Differance? ITR CTR cams???
I have a b16 and want to put some moderatly inexpensive cams in and decided to go with either ITR or CTR cams, but don't know the differance as far as power, torque, top end, 0-60, quarter mile, stuff like that. Someone please explain to me the pros and cons of each. I have the motor in my crx. Thanx
Maybe Next Time...
Maybe Next Time...
Guest
Posts: n/a
I believe the CTR rev's higher, but makes less power then the ITR. That should give you some idea.
CTR
Engine Type B16B
Engine Watercooled IL4 DOHC VTEC
Displacement (cc) 1595
Horsepower (PS/rpm) 185/8200
Torque (kgm/rpm) 16.3/7500
ITR:
Type: Inline-4
Displacement: 1797 cc
Horsepower: 195 bhp @ 8000 rpm
Torque: 130 lb-ft @ 7500 rpm
Redline: 8400 rpm
Performance
0-60 mph: 6.2 sec
0-100 mph: -.- sec
Quarter Mile: 14.8 sec @ --- mph
Dontsleep: That's the cam profile of the CTR.
CTR
Engine Type B16B
ITR:
Type: Inline-4
Redline: 8400 rpm
Performance
0-60 mph: 6.2 sec
0-100 mph: -.- sec
The 99-00 itr cams are for all intents and purposes CTR cams. There will be no noticeable difference between the two. in 9-97 the intake cam on the itr had 3 degrees less duration. The exhaust cams on the two have always been the same.
Gracie Barra Clearwater
Guest
Posts: n/a
[QU073][1]0|21g1|\|4lly p0573d by KJ [/1]
7h3 99-00 17|2 c4m5 4|23 f0|2 4ll 1|\|73|\|75 4|\|d pu|2p0535 C7|2 c4m5. 7h3|23 \^/1ll b3 |\|0 |\|071c34bl3 d1ff3|23|\|c3 b37\^/33|\| 7h3 7\^/0. 1|\| 9-97 7h3 1|\|74k3 c4m 0|\| 7h3 17|2 h4d 3 d3g|2335 l355 du|24710|\|. 7h3 3><h4u57 c4m5 0|\| 7h3 7\^/0 h4v3 4l\^/4y5 b33|\| 7h3 54m3. [/QU073]
c0|2|23c7
c0|2|23c7
2001 ITR Intake Cam is the same as the CTR Intake Cam. The Exhaust Cams are both exactly the same for all the Type R cams. The Civic Type R intake cam has 3 degrees more duration and a bit more lift. Its a bit more agressive and looking at both cams the ctr cam has probably about a finger nail more thickness. ITR has 1 engraved line by distributor side and CTR intake cam has 2 engraved lines by the distributor side.
03' BMW 330XI
03' BMW 330XI
