who knows there shizzzzzzit????
completing an almost usless swap.but know when the car starts it idles rough and when trying to rev up it dies.its a d16a1 into a 1st.gen crx.does anyone know what i might be missing. im starting to miss my car
sounds like an ignition problem check you plugs, wires, dist cap and rotor, and make sure your dist matches your ecu.
... content in sig not work friendly
Is your crx a si? Is the motor multi port or dual port? Are all the parts from the motor i.e. the injectors and dist. from the same generation? Obd 0. Take a spark plug out and ground it to the head, have someone start the car and make sure your getting spark. What is the ecu code?
Josh
I just found this:
D16A1 Acura Integra 1986-1987
D16A3 Acura Integra 1988-1989
Josh
I just found this:
try swaping you're tps & map sensor plugs... i wired a buddy's b16 into his ek & his car was doing exactly what you're car is & all that was wrong was the tps/map plugs where swapped
thank u 4 the help ..it ended up being the E A C V. would not let it idle up!!! the loss of spark was the igniter,thanks. it running now and im looking 4 a dyno tuning
