question on Manifolds
Are there any differeneces in intake manifods from a gsr to a ls...also is there a differenvce between a Auto LS manifold and a manual...
i ask these qustions because i was looking at a pic of a ls motor in someones hatch and i have a breather line on the valve cover. and there is a some type of valve on the intake manifold on the top.
thanks for any answers
actually any competant welder can easily modify a b18 manifold to accecpt a b16/b18c5 manifold if u get a b16 intake gasket and line it up you will see its only 1 flange need to be cut. i will have one on my swap once done. ill take some pictures of how it turns out
you can also do the same to a gsr head but its alot more complex
