PDA
View Full Version : Honda/Acura Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
  1. Courtney Cambell
  2. JDM guage Cluster Question SiR II into USDM
  3. B series oil pumps
  4. short shifter question
  5. No sound after installing Jensen Dvd Player
  6. tb, im, and dizzy indentification help plz
  7. EX Tranny Trouble ASAP
  8. rear discs on a 4dr EG
  9. crx not starting
  10. Craziest Tach Holder !!!
  11. EBAY Corner Lights???
  12. PistonSlap or Bad Lifter?
  13. ITR throttle body
  14. crx ecu harness send to rywire..NEED HELP ASAP!!
  15. Healight frame/ radiator frame
  16. some help!!!
  17. clutch problems.. help asap
  18. manual tranny fush???
  19. need help!!! **255 50 16 tire into civic**
  20. need machine shop
  21. axles question
  22. ef swap questions
  23. auto to manual swap question
  24. what is this noise!?!?!?!?!?!?!?!
  25. D series distributor
  26. Need help!
  27. Question about the RSR exhaust
  28. n00b question but curious.
  29. Suggestions anyone?
  30. Will The GSR back Seats Fit in a 93 Civic Coupe
  31. I need the AC for a 93 Civic
  32. how much horsepower does that vtak give you
  33. k need some help...
  34. Its a sad day :(
  35. where to build from here......
  36. Am is screwed
  37. 90crx b16a swap...wiring questions!! HELP!
  38. Eg corner lights in oven?
  39. Anyone Got The Sites For Honda Codes
  40. opinions on a D16z6 high comp build?
  41. To all who say Ebay short shifters DONT snap in half
  42. where to buy exuast piping
  43. Where B20 Balanced?
  44. Problem with speedo in a 98 civic LX 4dr. PLEASE HELP
  45. Tranny questions
  46. what is
  47. new set up
  48. expierencing problems..
  49. HID... is it worth it?
  50. question on d series transmission...
  51. 97 del sol intake help!
  52. Quick questions...
  53. Help With Iacv
  54. trade rims
  55. Hondata tune?worth it?
  56. swap help
  57. clutch questions
  58. Those wanting to Turbo a 93 Prelude
  59. MSD ignition
  60. need some help
  61. EG Core support
  62. header spray
  63. Teggie Fuel pump help
  64. Accord Question..Need some help..
  65. The D16Y8, any ideas
  66. skunk2 intake mani. on b16a turbo?
  67. Rear Disc Swap
  68. turbo & hp ?
  69. Paintcode For "Chamionship White/Frost White"?
  70. IACV problems
  71. teg dash in 93 civic
  72. Brandon Honda Parts Job
  73. aight whos up for a job?
  74. integra meet 3-3-07 at race rock
  75. Prelude tailights on an integra: How to do and where to buy
  76. Help ...engine Codes...
  77. Help Some One Who Knows The Ins And Outs On Brakes
  78. need head gasket work
  79. dsm injector help
  80. $50 for someone!!
  81. tire interests
  82. hondata Kpro help
  83. obd0 VAFC1 intsall PLEASE HELP!!!!
  84. What seats Fit in a 93 civic?
  85. p28 redline / cel ?
  86. mini me swap
  87. NO WAY! GSR LEATHERS IN EK COUPE!?!? here's how...
  88. tire size Q's
  89. 97 civic window problem HELP
  90. p72 h22 question
  91. obd-o alternator = obd-1 alternator?????
  92. 94-01 DC2 Muffler On EF
  93. rebuild kits
  94. Custom Downpipe
  95. size difference?
  96. need help with brake lights
  97. question about my honda..
  98. For those of you that like to use zip ties.
  99. Cylinder Trim feature in Crome
  100. *** need to know how manny teeth are on a gsr fifferential*** ASAP
  101. b17 swap w/55 shot...need help with timing!!
  102. Difference Between S80 And Y80 Trannies **need Help**
  103. 3" turbo muffler? what brand or preference
  104. Looking for reputable mechanic and tuner!!
  105. Accord stalls ?!
  106. how does head gasket affecting timming???
  107. 2 ls heads f/s with work on them ''lmk''
  108. Vibration??????
  109. 93 integra
  110. Teg timing and tunning question...
  111. dc problem
  112. Intake & Distributor cap for a B16
  113. Question about K24 into 07 civic
  114. makes noise when clutch is not engaged
  115. z6 question
  116. sensors for I/M
  117. Coilover Questions
  118. 97 gsr vtec problem?
  119. windshield install????
  120. my door wont open
  121. gsr engine needed
  122. Need tranny rebuilt, who does it locally?
  123. I need help with these cams
  124. jdmfs show any one going?
  125. diy del sol seats in eg?
  126. Car Bogs
  127. Help with D16Y7 into 1992 Civic
  128. Scca 99'si
  129. Whats the diff of obd0 acura and civic harness
  130. d16 z6 head
  131. anyone ever junk a car.
  132. suggested comp ratio
  133. d16z6 tranny
  134. tranny?
  135. Fuel Problem??????????
  136. alarm fuse and draining battery
  137. Yo I Got Some Questions
  138. Hesitation Problems
  139. motor install???????what shop
  140. Want to turbo my gsr for cheap where ?
  141. Questions about a 04 TL
  142. In need of help!!
  143. idle 1990 civic hatch
  144. HKS wastegate II problems
  145. rsx head ligths ?????help!!
  146. code site for honda?
  147. What is the Best way to get factory paint off Honda wheels??
  148. quick question bout harnes
  149. my 91 civic idles high
  150. Teg sunroof glass flies off
  151. 1990 honda civic hatchback
  152. Clutch Master Cylinder
  153. loweirng a car
  154. axle on pre lude
  155. Obdo Ecu ?
  156. ek coupe + gsr leather rears?!
  157. CTR steering wheel fitment..
  158. how to take oil pump off crank
  159. stock fuel pressure on 99 ls teg?
  160. EF Hatch Seats
  161. Part ID....not the center on the hatch...
  162. Part identification
  163. Random smoke
  164. b16 cam and cam gears
  165. Arp Gsr Head Stud Torque Spec?
  166. have question need help
  167. Places to find parts locally
  168. oil pan problems
  169. cooling fans took a crap
  170. b16 Tuning
  171. WHICH ECU for my b16a ????
  172. lookin 4 a honda
  173. White Residue In Oil?
  174. i need help on rsx-s
  175. 91 crx B16A?????
  176. Suspension!
  177. D-series swap, PLEASE HEELLPPP!!!!
  178. My latest crx build...Lots of pics!
  179. quick question?
  180. Which IACV are compatible with a GSR ?
  181. Car stolen? Don't post it here...
  182. help civic idleing Problem
  183. ls head
  184. rsx rear leathers in a ek coupe?
  185. need ef ls help
  186. ls turbo help
  187. dc problem
  188. need d16 head help
  189. Need help installing seats.
  190. Need help......
  191. changin my tranny fluid
  192. Injectors For My Boosted Teggy
  193. need fender flares....
  194. need help/info
  195. built gsr break in question
  196. blowing fuse in civic
  197. paint codes....
  198. DIY valve adjustment
  199. I need some help with the Sol!
  200. Valve cover stud.
  201. lowered alignment ques?????????
  202. cracked oil pan
  203. b16 1st-2nd-3rd-LS 4th-5th ?¿?
  204. Available @ S&R Performance: Race gas, nitrous, meth, etc.
  205. what shop is most reputable for engine build?
  206. which cams will fit my set up?
  207. sohc vtec-e cam question
  208. anyone do paint/body work
  209. d16 single cam vtec help!!!
  210. light blue crx pics?
  211. Need a shop for machining
  212. Car Feels A Bit Sluggish Taking Off
  213. Name EVERYTHING i need...
  214. 1990 EF front camber
  215. headwork
  216. right hand drive conversion!?!??!?!?
  217. A treat for those who love spoon...
  218. Nneeed Soome Quick Honda Acura Expertise!
  219. Compression/Leakdown test...
  220. pictures of jdm stuff needed..
  221. gsr water pump teeth?
  222. 94 TEG shifter lock???
  223. where
  224. ls vtec help...
  225. body work measurements needed
  226. anybody did-s2000 engine in90crx /rsx trans?
  227. ecu trouble
  228. Mini Me Hell!!!!!!
  229. Where to buy O2 Sensor?
  230. Cant Get Spark....Need Help!
  231. Twin Turbo Civic????
  232. false revlimit ??????
  233. Whats Wrong With My Brakes!!
  234. LHT K20 turbo is done.
  235. Gauge Cluster ????
  236. Turn signal no worky worky
  237. New Track times on the K20/24 turbo
  238. need b series hydro tranny
  239. ? question on d16 swap
  240. Motor Build
  241. Lil smoke around vtec
  242. Looking for an S2K owner I came across today.
  243. My radio stock radio needs code, i dont have?
  244. help!!!
  245. master cylinder
  246. Custom ITB Question
  247. h22a usdm or jdm???
  248. injector resistor box
  249. b16a valve adjustment
  250. b18c1 vacuum lines help
