how does head gasket affecting timming???
i've read that the head gasket thickness affects timming, but cant get a grasp on it. if you go thinner than stock, i think you have to retard timming depending on how much thinner...n if you go thicker, vise versa... or something like that..
i figured that the distance from the crank to cam will differ but how would that affect timming when they are spinning at the same rate ( i know cams spin half as fast)... you know what i mean. also, i dont think its the belt, for its got the same # of teeths and the tensioner will take up/ give slack as needed. the BELT distance from the crank to intk cam should be the same right? cause of the tensioner.
im just asking so i can futher educate myself.
You are making the distance between the cams and the crank different, hence the geometry is going to change due to the deck hight difference.
I think the following notes are from Endyne:
B-series cam gears are 100mm in Diameter
The circumfrence of the cam gear is 314mm (100mmxPI).
Divide 360 degree by 314 = 1.14 degree per mm.
So for every 1mm milled off the head of block the cam gears will roll back (retard) 1.14 degrees at the cam or 2.3 degrees at the crank.
0.020 milled meaning 0.50mm = about 1.14 degrees retarded, so advance your gears 1 degree to compensate for the 0.020" mill.
John is a Mad Scientist!
"It's OK to Smoke V-8's" - Surgeon General
www.2NRWerks.com - NSX, S2000 & RSX specialist. AEM, Hondata Kpro & Crome tuning provider. Custom built F, K & B series motors. Custom "Safe" Nitrous Kits and NOS Refills (While-U-Wait). Suspension/Brake Specialists & Alignments for lowered cars. On the quest for 700whp S2000 roaming the streets early Spring.
To Schedule An Appointment Call: (813) 876-VTEC
<< Reputations are so overrated! Don't hate on me 'cause I build fast cars.
Think about it like this...
aint that the truth. If you got a question he has an answer
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
Nothing happens to your timing belt.
