D-series swap, PLEASE HEELLPPP!!!!
hey, if anyone can help please lemme know, i got a 92 four door civic, that i just swapped out a d15b7 and put in a d16y7 i kept my injectors, intake manifold, distributor, and ecu and harness, and i cant get it to start, its crankin mad slow, and is apparently floodin, cuz the spark plugs have gas on them when i pull them out... anyone know what the problem is and how i can fix it
did you get to see the motor run before it was pulled from the other car? Timing may be off..
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
well if it ran fine and you didnt change or screw with the timing belt, than it probably woulndt be that (+1 on any cel codes????) check the sparkplug wire order on the dizzy. does it run at all? check all your wiring and stuff as well it could be simple. good luck keep us updated with any more info.
no its not thrownin n e codes, and its not crankin fast enough to even start, right now startin it is m biggest problem... but thanx guys i'll take n e info u give me
like said..check all wires...make sure ur spark plug wires are in the right order...make sure ur battery is still good...make sure starter is hooked up properly all the little essentials..did u screw with anything on the motor..or just drop it in?
well i put the intake and injectors from the d15 on the d16 and the dizzy, other than that, jsut dropped it in, the battery is good and i'll double check wires... i'll let u guys kno later how its goin, thanks
