Clutch Master Cylinder
Old Jan 28, 2007 | 05:19 AM
willito4u's Avatar
Default Clutch Master Cylinder
My Clutch Pedal Is Getting Stuck If Im Not Mistaken It Might Be My Clutch Master Cylinder. I Changed Not To Long Ago The Clutch Slave But Not The Master.
Does Anyone Have A Link Or Something To Assist Me In Changing It If Thats What It Is? Or Maybe An Ideal On What Could Be The Cause Of It Being Stuck? Any Help Would Be Appreciated. Thanks!!!!
Old Jan 28, 2007 | 05:27 AM
hondachris1994's Avatar
hatchback1994
is it leakin fluid inside the car? Its really simple to change its 2 change its 2 bolts on the inside of the car and a carter pin u pull out, but make sure thats where its leakin from first cause it could b leakin from your slave
Old Jan 28, 2007 | 05:33 AM
TSX24L's Avatar
its recomended that you replace these both when replacement is being done on one or the other. I have to do mine later this month when i get to it.
Old Jan 28, 2007 | 08:31 AM
willito4u's Avatar
Well Theres No Leaks But The Pedal Is starting To Stick..... I Replaced The Slave About A Month Ago SO IM THINKING ITS TIME FOR THE MASTER BUT IM NOT SURE
Old Jan 28, 2007 | 09:22 AM
hatchback1994
If the master's not leaking its prolly not bad, try bleeding the system
Old Jan 28, 2007 | 12:50 PM
pepperinyoureye's Avatar
not only leaks around where the clutch pedal meets the MC but when you pump the clutch to you hear a noise like air leaking out?kinda hard to describe the sound but its kinda like if you were blowing up a balloon with a small hole in it
2000 Silverstone AP1
1998 Turbo SC2
Old Jan 28, 2007 | 04:45 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
+234098502
ive heard numerous stories of one failing when you change the other...
spend the extra $50 and do it right!
g/l
Old Jan 29, 2007 | 05:38 AM
willito4u's Avatar
Ok Will Do Thanks Guys .......
