turbo & hp ?
Old Feb 4, 2007 | 12:56 PM
CivicRacingFL's Avatar
Dorado, PR
Default turbo & hp ?
how much psi i can run on a stock d16z6 stock engine, with a p28 and how much hp output ill have.
Old Feb 4, 2007 | 01:36 PM
Eluzzionz's Avatar
everyone is gonna ask what turbo since it makes a difference..t3? and do u plan to upgrade fuel etc..there is no actual answer for this ?..but theres things u can do to make say 10psi on a t3 more reliable ..injectors good tuning etc...u can just slap a turbo on a go but dont be upset when it blows etc...if u want it to last do it the right way and build the motor first..or atleast get good tunin , fuel etc..
Old Feb 4, 2007 | 01:41 PM
Dorado, PR
t3 or t4, i was gonna chipped the ecu, try to run turbo on a safe mode into i can start doing a job on the head and block
Old Feb 4, 2007 | 01:48 PM
StrictlyBusiness's Avatar
Mr. Stealyogirl
go with the t3 for ur sohc, i ran a t3/t4 on the same motor an i didnt hit boost 2 second gear cuz the turbo was so big, an if u get it tuned u will have 2 chip the ecu, get sum1 2 tune it on chrome an u will be str8,you can daily drive a turbo car jus drive normal an ull mostlikely stay outta boost, talk 2 vega or John from modified racing they both do awesome tunes
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Feb 4, 2007 | 02:05 PM
Dorado, PR
tx
Old Feb 4, 2007 | 06:42 PM
60-1EK's Avatar
Engineer at the source
t3 disco potatoe or T4 PT67?....bla bla. Figure out what your power goals are and then you can decide on a turbo. Then you can determine with your setup, what you can run..or
Save your money and invest it in something other than a turbo d-series honda.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 4, 2007 | 06:43 PM
60-1EK's Avatar
HAHAHAHAHAHAHAH. That is awesome.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 4, 2007 | 06:49 PM
mtber's Avatar
Old Feb 5, 2007 | 06:04 AM
Dorado, PR
what would be the best setup to run a turbo kit on a stock d16z6 eg hatch
Old Feb 5, 2007 | 06:33 AM
slovvcrx's Avatar
Google Homemadeturbo.com
