need help with brake lights
I have a 2000 civic si and my brake lights wont work. I replaced the switch behind the brake pedal, checked all fuses under the hood and under the dash, also checked all the bulbs. the rest of the lights work fine, running lights ,turn signals, reverse lights ets. just no brake lights. any advise would be appretiated
did you check your horn to see if it work?
-CmC
-CmC
00 FBP SI
For Sale
CL Type S injen Cai (Sold) & 04-08 TL OEM Rear Spoiler.
https://www.tamparacing.com/forums/h...r-spoiler.html
00 FBP SI
For Sale
Are you getting 12v to one side of the brake light switch/wire?
and do you get 12v out the other side of the switch/wire
when you press the brake pedal?-Bob
and when you press the pedal, do you get 12v back at any of the brake light/wires at the back of the car?-Bob
Enable your private messages, and I can get back with you easier.
Sounds like you already spent some money on parts.
If you want someone to look at it, get back with me.
I can show you how to trace the 12v.-Bob
This problem is a how-to, to track down an electrical problem.
Sending it to the top.
sorry to advanced for me not sure how to do that.
