which cams will fit my set up?
FUCKIN LOOONG BEDD!!!
on
ok so im buying a set of cams with in a week or two.heres the thing im not sure what will clear my set-up....this is the set-up
b18c block (jdm gsr)
ls crank
rev rods
wisco 11:1 pistons
b16a2 head
full rev valve train
.5mm over sized valves
its 12:1 comp after its added up with the stroke and pistons
now,with the LS stroke being longer than a GSR and the .5mm valves what will clear?skunk2 says not to use their stage-2 or stage-3 cams with over sized valves.and i really dont want stage-1 so if anyone can help that'd be great.
ls crank
rev rods
wisco 11:1 pistons
b16a2 head
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
well if they dont recommend it...its for a reason...i doubt u should of went with oversized .. not really a reason too...im sure someone could tune it and make it work...either way goodluck....
The problem with the oversized valves w/ the stage 2 cams is that the valves can hit each other, not really the piston so much since Wiseco should be able to accomodate a .5mm oversize on the valve no problem. You will need to check valve to valve and valve to piston clearance before final assembly of the head.
on
head is on the car and has been running for bout 6 months.so much for checking before final assembly i guess.....now what should i do?
ive heard of claying, what is this and how much does it run?
and as for skunk2 pro stage1 i really want more power then that...ive spent to much time and money to settle for a mild cam and little power gain.
I dont think that you can go over a stage 1 cam, with any brand, due to the oversized valves. I looked into this when I was going to get cams and valves. I ended up getting stage 1 cams so that I could upgrade the valves.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
Skunk2 pro 1's are a big cam. Lift is greater or equal to the older stage 2's. The pro 1's are not a small cam.
You need to pull the head to clay check valve to piston clearances. This involves installing and removing the head several times and cranking it over by hand each time and taking measurements with vtec locked. In order to check valve to valve clearance the head will need to be removed also. The way I did it in the past was to install the head and cams onto a spare b16a block that had a crank in but no rods or pistons. I cut a hole in the side of the block for a window and then threw a timing belt on and rotated the motor and measured the valve to valve clearances with feeler gauges at different cam gear settings. You could also put the head on a set of head stands and fit a custom belt on there that just fits over the cam gears only and keeps them in time, I've seen pictures of people doing this although I don't know where to get the belt at. I've also heard you can put the head on a set of stands and use a standard timing belt that is pinched with a set of vice grips, never seen this one work though.
Also when checking valve to valve you will need a spare set of rocker arms for one cylinder that have been modified (ruined) to keep both valves locked into vtec. To clay check you can use your good rocker arms and just swap the pins.
Hope this post made sense.
Nope, one mis-shift and go-boom!
what header? if its a "el cheapo" header, why don't u add 156456456456 shot NOS instead!
What intake manifold, what are you using for tuning? What gearing? What kind of power are you looking for? mid range? top end?
