Teggie Fuel pump help
Old Feb 4, 2007 | 07:09 PM
pubes2942's Avatar
Question Teggie Fuel pump help
Hey, i gotta 90 DA and the fuel pump wont turn on when i put the key in, wont start nothing. Checked the fuses and there all good. What do you think it is? the main relay????
R.I.P. DA9 - 4/4/07
Old Feb 4, 2007 | 07:22 PM
aznkhmerracernza's Avatar
a ground in the wiring harness or the main relay. Check the Ground on the thermostat, one on the tranny, and one one the valve cover.
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Feb 4, 2007 | 07:43 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
Just pull the seat and get a Multimeter, see if you are getting voltage to it first of all. There is no sense on going on a wild goose chase just to find out that the pump took a Poop. If you dont have any voltage then go from there. Check all your fuses (If you havent already), Make sure that it has a ground, etc.... Good luck
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Feb 5, 2007 | 07:14 PM
Grizzly0205's Avatar
**BoTtLeS aRe 4 BaBiEs**
will it try to crank over???
Old Feb 5, 2007 | 07:21 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
+ 6 billion.
start with the fuel pump, make sure it is getting proper voltage.
if not, THEN you start tracing wires.
g/l
Old Feb 5, 2007 | 07:37 PM
Just saw that you live in Palm Harlem, If you need help send me a PM and i can try and swing by after work and give you a hand.
