Car Bogs
Car Bogs
Here's my problem. I have a LS/VTEC and things fixed but problems continue to occur. I fixed the Coolant to Oil Mixture and Now i'm having Bogging Problems. I haven't done the 3 Wire IACV to 2 Wire IACV conversion or the CFK Sensor Conversion yet. My problem is that When i Rev it to 3000 RPM it Just revs up and Stalls and bogs out At WOT. Here are some mods that may cause the problem. I have a Adjustable Fuel Pressure Regulator Which came with the head when i bought the head. The 240cc Injectors it came with Froze shut and Now i'm Using 190cc D16Y7 injectors Temporarily. From what i Kno Timing can cause the problem but it doesn't seem like a Timing Issue. I do not know the Fuel Pressure. Do anybody have any clue? Would Getting tuned help fix the problem?
How did u fix the coolant to oil mixture, with a new headgasket?CFK conversion wtf is that, I thought that sensor was built into the dizzy?
Naw headgasket was fine. But I accidently ran a Coolant hose into a Breather inlet. Don't know why i did that. But no CFK is Crank Fluctuation Sensor and the sensor your thinking about is Crank Positioning Sensor.
I believe thats a cmp, and they are 190cc injectors could def be a problem but as far as I know almost all honda injectors are 240 check with phearable he has all of the specs.
United States Marine Corps
6322 Comm-Nav Tech
PFC
RAH!
6322 Comm-Nav Tech
PFC
RAH!
What's a CMP? Yeah i have 190cc injectors. The DX injectors are 190cc.
Yeah Im throwing some codes. The thing is my Guage Cluster broke soo my CEL light won't come on. I have to hook up a scan tool to it and find out.
