ls turbo help
ls turbo help
i want to work on the body of my 94 si h/b first but i want to get an idea of what to do i want to go turbo i heard that an ls can hold 14psi on stock internals i don't know if it's true but tha's what i heard i wan't to be able to run more then that i would like to send it out to a shop where they can do what they so i can run more boost i don't know what has to be done so that's why im asking i know what they say "speed cost money how fast do you want to go"$$$$$ i want to build the head and the block too. P.S i also need it to be a/c friendly.
so what are u asking about...what to do...everything?...
sleeves
crank
pistons
rods
arp headstuds rod bolts
ss valves
dual valve springs
ti retainers
port n polish
although i would get a vtec head and use it instead of buildin ur ls head...u would gain a LOT more hp that way...
if u want i got a eagle crank they retail for $799 make offer...its 89mm ls crank
sleeves
crank
pistons
rods
ss valves
dual valve springs
ti retainers
port n polish
Its not how much boost the motor will hold, its how much hp. 14lbs on a t3 is tottally different than say 14lbs on a sc61, so the question is how much whp are you looking to get? stock internals on a ls will hold to around 300whp, just have to get a damn good tune.but first thing i would beef up is internals, rods/pistons/head studs/rod bolts. and if your looking for crazy hp then get it sleeved, but that is pricey and iono what your budget is, there is also the block guard option which is what i have and is alot cheaper. if your looking to stay with the ls head than id go with port/polish and a nice set of cams along with spring/retainers and maybe some valves. or you could go ls/vtec and throw on a b16 or a gsr head and call it a day. p.s comma's and periods are your friend oh yeah dont forget bigger injectors and fuel pump
