p28 redline / cel ?
Old Feb 2, 2007 | 07:01 PM
lzylst's Avatar
Default p28 redline / cel ?
Can a CEL alter the stock 7200 redline of a virgin p28? I know it's not the ecu, just for the record.
Vance @ 863-604-2139 for any questions
Old Feb 3, 2007 | 05:41 AM
hondachris1994's Avatar
hatchback1994
check the code and see what it says, and no that shouldnt make your CEL come on
Old Feb 3, 2007 | 07:16 AM
lzylst's Avatar
despite the code , will it alter the redline?
Vega speek up please
Old Feb 3, 2007 | 09:02 AM
Derka's Avatar
TR Balla Donor Supreme
If it is throwing a code such a vtec sol. or press. sensor, it can alter the redline, and go into almost a sort of limp mode.
1998 crv daily beater
Old Feb 3, 2007 | 09:29 AM
mtber's Avatar
Various issues with a vehicle could cause a phantom revlimit of sorts.
A bad ecu throwing a constant MIL regardless of the service connector being connected could also do this.
I don't understand the point of this thread.
Fix the MIL/CEL and proceed from there.
Old Feb 3, 2007 | 05:57 PM
lzylst's Avatar
Ok, no more MIL/CEL (fixed). I have tried two different virgin p28's and both allow redline to go past 7200. I stopped at 7500rpm because of potential valve float on stock springs.
Could my OEM tachometer be off the mark by that much?
Old Feb 3, 2007 | 10:33 PM
mtber's Avatar
Yes considering the ecus are supposedly oem.
I have seen an aem tach be off by up to 800 rpms.
Old Feb 4, 2007 | 12:13 AM
lzylst's Avatar
Yes, the ecu's appear to be virgin inside. Wow - off by 800+/-!
Thanks John.
Old Feb 4, 2007 | 07:58 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
vance..going through same thing on melissas coupe....no matter what ecu...p28 p30 p72 p06...all the same thing....hooked up external tach(autometer) and is revving to correct rpm unlike stock tach, which would be either 6800 and sometimes like 8000...depending on outside temp...but always stock rev limit on autometer....just figured id let u know, at least im not the only one with this prob...lol
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Feb 4, 2007 | 09:45 PM
Eluzzionz's Avatar
my stock tach is off from my autometer about 200rpms..but now i think my ignitor is going out cuz it just jumps around while drivin..hittin like 10k etc
