90crx b16a swap...wiring questions!! HELP!
when having a 1990 crx dx model and doing a b16a(obd1) swap, electrically speaking, what is involved?i know to buy an obd0--obd1 conversion harness. do i have to buy an hf or si harness and mod it for 4 wire o2,vtec,and other shit? when it comes to wiring i hate fuckin wit it !! please help
thanks
thanks
image removed from your sig...see forum rules
Rywire - Online Store has everything you need if you want to make it a plug and play affair.
Otherwise, you will need to do the DPFI to MPFI conversion on your Dx harness and add all the necessary plugs. You will need an OBD1/2 distributor, 4 wire O2 sensor and pre-obd (OBD0) to OBD1 conversion harness. NOT the OBd1-2 harness.
