cooling fans took a crap
Old Jan 26, 2007 | 09:13 AM
nomad's Avatar
Default cooling fans took a crap
could anyone give me any suggestions on what fans to go with??
Old Jan 26, 2007 | 09:25 AM
mtber's Avatar
What fans did you have ?
Are you sure the fans are dead & your fan switch is still working ?
Old Jan 26, 2007 | 09:54 AM
SmokinS13SR20's Avatar
That ginger...
Junk yard honda fans FTW, Seriously, thats what ive done on my buddies cars before, made it look clean and worked flawlessly
Old Jan 26, 2007 | 12:45 PM
nomad's Avatar
i have fal dual fans i haven't checked for sure but there 5 years old. and this week when i was on my way home from work my water started going up and the fans never came on.
Old Jan 26, 2007 | 05:01 PM
sprjit22's Avatar
Rick James bitch
check the sinsor... Common problem.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Jan 26, 2007 | 06:04 PM
civicized's Avatar
pull the electrical connector plug off the fan switch located at the thermostar housing. Take a two inch piece of wire or paper clip and jump both connectors on the plug cap with the key on. If they fans fire up it likely is the fan switch.
Take it off. Put an inch of water in a pan on your stove. Set the non-electrical connector end of the fan switch in the water and boil for a couple minutes. Check two metal prongs on electrical end with ohm meter or test light while still in water. Meter should go down toward zero if it is working or light on test light should come on.
Old Jan 26, 2007 | 06:52 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
FAL Is da sheeeeetttt....
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Jan 27, 2007 | 12:46 PM
civicized's Avatar
Powered test light, by the way. If you use a regular test light, nothing will happen. Just wanted to make sure you realized that.
Old Jan 27, 2007 | 07:55 PM
I concur with civicized.-Bob
