- 86 Hardbody z24 lost all power while driving
- Does everyone have trunk rust? s13
- Dash swap question...
- 92 Infiniti G20 Question
- crazy chattering/ clicking noise
- Beams 3SG/6spd into S14?
- sr20det need help!!!!
- Scott/Enthalpy
- S14 5 lug front bearing/hub issue #5698
- in/out fuel lines on afpr
- Auto => Manual Swap Q's: 5-Spd drive shaft vs Auto drive shaft...
- Good site to buy a complete s13 front clip?
- KA24DE throwing code 12 help plz
- s14 engine harness
- Ka24De wont rev pass 2500rpm new to this please help need car bad
- Z32 bmc t/o
- ka24de Engine Harness ?
- stretching tire on a 17x10.5??
- which helicoil to use..
- Seat ????
- Rb26 crank question
- 2jz swap in s13 help
- DS support bearing
- question about IACV and AEM
- Bout them Ka rebuilds...
- super annoying squeak (s14/coilovers)
- Oil pressure issues
- ka injectors won't fire
- HELP...ka-t breaking up in mid boost...HELP
- alignment! !! any suggestions //?
- Subframe / Rear Suspension question....
- vq35 question
- Help s13 KA Need to run richer
- solution to excessive rear end sway? (s14)
- 04-06 maxima/ infinity 5 speed auto shift problems?
- Using a lifeline..JDM WIRING PROS I need your help!
- KA24DE timing issue
- where to get Hawk pads 'locally'?
- ka24de idle stall
- Code 21 1987 Nissan Pathfinder z24i
- KA24DE CAM swap options! some feedback on how each cam setup feels! FAQ!!!!
- Help plz
- rb25 ticking/knocking. think tank time
- sr20det help needed
- Couple of electrical questions---s13
- guys i need some help please. suspension questions
- 2002 Infiniti G20 Starter Replacement
- reman j30 axles?
- Dare i say WIRING ISSUE!
- Altima Ka24de Distibutor Question
- Front Struts; Why Does the Left Side Cost More Than The Right?
- nissan tuning questions
- rb25 in s13 need help
- KA24DE Knocking HARD
- KADE Idle = 5100RPM!!!
- s13 ka into s14
- KA-T Misfires and runs rich when cold
- Pledge great for cleaning interior
- breaking up when entering boost help s13 blacktop
- s13 clutch bleeding issues
- z32 brakes 26 or 30mm?
- New Port Richey US 54 - Need some help with hatch
- launch control in s13? can anyone do it
- Excessice SR20DET blow by question
- blown head gasket help!!! :(
- Need options for trunk hinges
- CV axles dimensions ?
- Weird Intake issue. Car will only start when Intake is angled Help
- S13 Rb25det clutch master cylinder problems
