2 questions in regards to s13 diff
Old Oct 2, 2012 | 07:27 PM
KRUKED's Avatar
.....taste the rainbow
Default 2 questions in regards to s13 diff
1st)...
The stubs on the diff that the axles bolt to...
What is the "correct terminology" for the seals inside the diff, wrapped around the axle stubs?
2nd)...
Are said seals in question difficult to change?
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
Old Oct 2, 2012 | 10:45 PM
omgosh's Avatar
I wanna say the they're called output shaft seals, or maybe axle flange seals . The one in the front being the pinion seal.
IIRC, to take them out, you just take the cover off, and unbolt the bearing caps (bolts are really tight lol).
Old Oct 3, 2012 | 03:28 AM
Jr_SS's Avatar
S one 4
You should be able to pop the axle shafts out and pull them out with a seal puller/screw driver or anything of the sort. Then pop you're new ones in without ever going inside your diff... Obviously, clean the area thoroughly and try to prevent scoring the seal surface.
Old Oct 3, 2012 | 09:25 AM
KRUKED's Avatar
I imagine that they would have to be bolted back to spec, right?
How would I just pop out the shafts? I figured they'd be fastened from the inside, thus the gears having to be unbolted and the lot
Old Oct 3, 2012 | 09:33 AM
KendallH's Avatar
JDM cavaliers
http://www.nicoclub.com/FSM/240sx/91-94/PD.pdf
Originally Posted by PJ Prendergast
i went to a scrapyard in Kilcock today looking for my 180sx tail lights, no luck though
...and then I wondered why I was on Stanceworks forums...
Old Oct 3, 2012 | 10:01 AM
Jr_SS's Avatar
S one 4
Rubber mallet will pop your side flanges out, if you have to, use a slide hammer.
Old Oct 3, 2012 | 10:43 AM
KRUKED's Avatar
Originally Posted by KendallH
I seem to always forget about the FSM. Thanks.
Yea, I just looked at the guts...the shafts are splined in. I'll try a slide hammer and see what happens. I had the diff welded Sunday and rinsed/pressure washed everything afterwards. It's a little rusty inside do to the water residue so I'm pretty sure it's going to be a slight bitch trying to use a mallet.
Old Oct 3, 2012 | 11:28 AM
KRUKED's Avatar
Thanks Jr. The shafts popped right out w/ a slide hammer and the seals were right there. Now I just need to track down the seals.
One more question. The diff classification, it's an r200, right? I know it wouldn't be an r200v because the "V" would stand for viscous.
Old Oct 3, 2012 | 01:03 PM
Jr_SS's Avatar
S one 4
It shouldn't matter. All R200's have the same diameter stub axle just different lengths.
Edit-
http://www.courtesyparts.com/38342-s...4-p-69911.html
http://www.courtesyparts.com/38342-s...-p-137328.html
http://www.courtesyparts.com/38342-s...2_883_953_974&
Old Oct 4, 2012 | 01:43 PM
omgosh's Avatar
Haha nice, I must have been thinking of taking the internals of the diff out.
Blackzenki82
Nissan/Infiniti Tech
12
Jun 12, 2011 06:59 PM
JDMjunkie
For Sale/WTB Nissan
18
Jun 12, 2009 05:33 PM
Rotary7
Aug 19, 2005 03:05 PM
_Charles_
14
Apr 12, 2005 07:15 PM
