trans problem,need info.
ok guys and gals. i have a 89 s13 sr20det manual transmission.
im having a problem .
as i release the clutch in 1st, sometimes it grinds . i push the clutch back in ,grinding stays.and when i shift it into nutral it goes away.
does same in reverse.
SLOW speeds as in traffic .
it goes in and out of gear as normal.
no other issues as far a shifting goes.
im guessing syncros ?
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
1972 nova ss
89 240 sr20det
synchros are usually when going in gear, not while in gear.
in my experience, grinding noises while in gear like what you are describing tends to point to clutch issues.
could be something dumb like the gear lube leaked out.
if it was the clutch system, then you would have difficulty shifting. And I doubt there would be any noise associated with that.. not that I've ever experienced anyway.
It kinda sucks, but I'd start with dropping the tranny and seeing what it all looks like. Hopefully you'll get lucky and it will just be something like a bad pressure plate or something like that. If everything checks out, then the tranny might be on its last leg.
cagedeyecam
Nissan/Infiniti Tech
5
Oct 26, 2010 03:52 PM
tony122
10
Aug 5, 2008 06:41 PM
