ae86 with sr20det help
Old Jun 16, 2012 | 01:04 PM
alexcuban15's Avatar
Default ae86 with sr20det help
i have a sr20det in my ae86
mods:
acl rod bearing
acl crank bearings
arp rod bolts
arp head studs
new oem rings
garrett gt2871r (s14)
isis intake
megan downpipe
blitz bov
stock internals
cosworth hg 1.5mm thick
Now i need to know what my compression would be with this head gasket?
Block has never been decked.
Head never warped, just had it resurfaced because of new head gasket.
And what would be safe to boost? its at 12psi now...
Old Jun 16, 2012 | 03:11 PM
Jubee's Avatar
Baby Rhino
when you say GT2871 (S14) are you meaning you have a S14 sr turbo or you have a actual gt2871r There is a diffrence
Old Jun 16, 2012 | 03:15 PM
Gil14's Avatar
Was thinking the same thing. You can have a Ball bearing or non bb t28. Or a legit Garrett GT2871r. the gt2871r isnt factory for any motor.
Old Jun 16, 2012 | 10:54 PM
Empire's Avatar
buildin' it
not sure if the turbo really matters...
the way it is worded implies that everything was all set up and running before and the onlything that is different is the headgasket.
if that is correct, then the change in compression is minute.
but when it comes to how high you can crank the boost, pretty much regardless of setup, you are limited by your tune.
so going to a real tuner, getting a true accurate tune done will tell you exactly what boost levels you can run.
if you can a crap tune, you can damage things just with a conservative boost level.
Old Jun 16, 2012 | 11:00 PM
s14 turbo bb
sorry for confusion
Old Jun 18, 2012 | 02:43 PM
Jubee's Avatar
Baby Rhino
ok so you have a T28 so i am guessing you could prob run maybe like 16 psi i am not sure though.
Old Jun 19, 2012 | 06:57 AM
Gil14's Avatar
Is it a DD? If so i wouldnt run too much more than 12psi, becomes less and less reliable the more past 12 you go.
Old Jun 19, 2012 | 07:16 AM
mewantkouki's Avatar
no
You need larger injectors and a re-tune if you intend to run more than 10-12psi on a t28 unless you want to run lean and detonate or melt something.
Tayloray
Jan 14, 2012 10:16 PM
xavy
For Sale/WTB Toyota
Dec 11, 2010 05:01 AM
Jubee
Jan 24, 2008 10:04 AM
