s13 clutch bleeding issues
Old Sep 7, 2011 | 11:38 AM
b13steve's Avatar
Default s13 clutch bleeding issues
92 s13, ka motor. removed dampening box, new master and slave cylinder. gravity bled and reverse bled ( pumped air back thru lines out the master till no bubbles came thru ), pumped the clutch and bled thru the slave also. still have half a pedal and is not fully disengaging the clutch! so that leaves what?
JDMinnovations hollywood, fl
93 del sol.....z6 on 8psi......201...daily beater
91 talon tsi.....25psi.......467...weekend sleeper
I do DP to MP swaps and full obd-1 for EF
352-364-6384
Old Sep 7, 2011 | 12:46 PM
Empire's Avatar
buildin' it
still has air in the lines.
a leak
air
a bad master
air
Old Sep 8, 2011 | 05:57 PM
b13steve's Avatar
no leaks, tried 2 different masters and slaves.
352-364-6384
Old Sep 8, 2011 | 06:10 PM
omgosh's Avatar
That leaves:
the line
fittings
misadjusted/fucked up clutch pedal
bent master rod
all cylinders are bad lol
air
you suck at bleeding
bent clutch fork?
Just go over the whole system beginning to end
BABYBOY8782
Feb 11, 2009 10:59 AM
minitruckinxxxx
Apr 14, 2008 03:46 PM
slowboy
Aug 29, 2005 01:35 PM
milesengineer
May 3, 2005 04:35 PM
