Help plz
I have a 95 s14 and my radiator had a big crack in it. I replaceed it but then after the new one was put in my car started to over heat, been bleeding the air out and i then replace the thermostat and gasket but nothing works. Can any one help with some advice on what i should do or check. Thank you
Did you put the front is up on ramps or jack stands? Even a steep driveway or on a hill to get the angle of the motor "up", so the air will search for the open radiator cap. If your bleed screw hasnt been snapped off open that too. take your time, keep filling the rad and watch the bubbles for about 2 beers with a friend or two and you should be good to go.
-Royce
-Royce
Edit: you need to put your font on jackstands or something. Shit is dinky
Check how hard the fans are blowing, like hand between rad and motor. Now check fan strength of non overheating car with same motor. Bleed lines right. Make sure your using a 50/50 mixture and not all coolant or all water. Make sure water is Not just tap lol. Last but not least make sure your thermos not just tarded
If you can't figure out the problem, run your air on full blast heat and aim vents away from you to keep it from booming up
I love my honda, when it pressure washes my nissan.
Build threads
S13 coupe
https://www.tamparacing.com/forums/n...ht-purple.html
Kouki
https://www.tamparacing.com/forums/nissan-builds-projects/688726-kouki-project.html
Build threads
S13 coupe
Kouki
Half antifreeze half water Full car with bothFill overflow tankStart carTurn heater onWatch for 20minutes with cap offShut car offPut cap on and start car with the heater still onCome back an thank me
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
