Setting up power source...
Ok so I decided to just go ahead and attempt to setup a power source for my accessories.(gauges, controllers, etc.) Its just that I have no idea on what to get(fuse block, relay, distribution block). So need help deciding in what to get. Highest current being pulled is 20amps for my fans other stuff is half that size I think.
Setup will be:
??gauge wire > fuse block > relay > distribution block > accessories
So my questions are:
1. What size/kind fuse block should I get?
2. What kind of distribution block should I get?
3. What kind of relay?
4. What gauge wire from battery to fuse block? Fuse block to relay? Relay to distribution block?
Thanks
Setup will be:
Thanks
You really shouldnt have that many add on's that you need to add another fuse or relay block, there are unused locations in the factory pieces.
If you REALLY somehow did manage to, I'd replace some of the factory stuff with something larger from another nissan/infiniti vehicle, j30, q45, etc.
