Can not find the power source to the ac fan on EG
i am not sure if this eg used to have ac or not.but
i can not find the power source to the ac fan..
i thought there is a connector somewhere near the driver side
headlight..but i can not find any power source
and is that power source pre-wired even though
the ac was not equipped with ac system when it
was new
or is power source located on compressor cause i can see a red cut wire
that seems to be a power source but with no connector interface..
and if i can not find that power source..does that mean
i have to run that wire diy ??
help help .deeply appreciated
thanks
was new
thanks
yea there should be a connector at the end of that wire. 1pin or 2 pin. On the other end of the engine harness that goes to that connector iam sure you could rig something up or find the right connector from a yard or someone on here with a spare parts harness.
