KADE Idle = 5100RPM!!!
Old Sep 16, 2011 | 09:50 AM
RodFarva's Avatar
Default KADE Idle = 5100RPM!!!
I need some help again. I finally have everything together and plugged in on the engine, tried to start it up and the engine immediately jumps revs to 3000 and then keeps climbing fast at first then slowly after that. I know that I covered all of the vacuum barbs on the IM when I did the emissions delete. I looked at the IAC on the back of the IM and what I think is the adjustment screw is buried in the IAC. I don't know what to do now, any help is appreciated. Thanks!
Old Sep 16, 2011 | 10:19 AM
mewantkouki's Avatar
no
Adjust the tension on your throttle cable and check tps voltage... There isn't anything that would cause an engine to almost hit the limiter unless somehow it was being or thought it was being revved.
Old Sep 16, 2011 | 10:20 AM
cjackson2802's Avatar
Originally Posted by mewantkouki
Adjust the tension on your throttle cable and check tps voltage... There isn't anything that would cause an engine to almost hit the limiter unless somehow it was being revved.
+1
Old Sep 16, 2011 | 10:34 AM
RodFarva's Avatar
I'll check the voltage next, I tried to start it up a few weeks back with the same results. At that time I didn't have the coolant system completed (I was too excited and only ran it for about ten seconds). I adjusted the cable tension already so I'll hit up the TPS.
Old Sep 16, 2011 | 10:36 AM
Check base timing, and fuel pressure.
Old Sep 16, 2011 | 10:52 AM
no
Start it with the tps and throttle cable disconnected.
Old Sep 16, 2011 | 03:25 PM
Blu813SD's Avatar
I Want a Damn 240 Coupe
Even if the throttle cable is disconnected you may want to look inside and look to see if there is any noticeable openings. Reason being is even with the cable disconnected, there is a small adjusting screw located at the bottom area of the throttle body that also controls how far open it is. The cable is just for throttle response. But like they said also check the tps and voltage.
Old Sep 16, 2011 | 08:20 PM
omgosh's Avatar
TPS wont make it rev by itself. ECU can add all the fuel it wants, but its only able to combust it because you're drawing in way too much air from somewhere.
Old Sep 19, 2011 | 07:46 PM
RodFarva's Avatar
I'll try some of these diagnostics on Wednesday, won't have free time till then.
Old Sep 23, 2011 | 07:24 AM
RodFarva's Avatar
I unhooked the throttle cable and the TPS. The engine wouldn't maintain any idle, it sputtered once or twice jumping to 1K then died. There is a video on youtube on adjusting the TPS I'm going to check it's voltage then get back here. Thanks for the suggestions.
