KA24DE CAM swap options! some feedback on how each cam setup feels! FAQ!!!!
well, i found this on another site, so i thought i'd share, i havent tried any of these out, i take no credit in making this guide, im just reposting it for everyone on TR, enjoy bitches!!!
ok as requested, heres what each cam comes from...
248 - S13 exhaust
232 - S14 Intake and Exhaust
240 - S13 Intake
all of the impressions here are based on a 92 s13 hatch, automatic, fully rebuilt to stock by me, except apexi panel filter
i've tried 248/248, 240/248, 248/232, 240/240, and now i've tried 248/240
its been a while since i've tried any other cam swap besides 240/240, and i've never had 248/232 on the automatic
248/248 - is by far my least favorite cam swap. there is a noticable loss in low end, and the motor never rev's high enough to take too much advantage of the additional top end power. I'm not saying the top end isn't there, it just really only starts pulling until right before 6000 rpm, and pulls to 7000. then you hit the rev limiter and crave for a few more revs. maybe an automatic ecu and 7200 rpm mighyt be beneficial, but i love to rev it out and i shouldnt be allowed to have
240/248 is obviously stock, its been a while since ive actually had a car with 240/248. but from what i remember the low end is decent but it does fall on its face in the top end. the 248 exhaust cam is trying to make top end
232/232 - i never tried, but i got em so i could.... but come on 232/232?
240/240 - has a really snappy low end, probably the best low end ive tried, and its the only times ive ever spun the
248/232 - this is hand-down where its at. If you have some s13 cams and some s14 cams you should have already done this. the power production is great everywhere. you only lose a little bit of top end over 248/248 and you gain more low end than you get with any other swap besides maybe 232/232. the KA craves this swap, it loves the low end and, chances are you only rev to 6500 anyway, so thats why this is the cam sawp for you. only don't do this if you wanna get beat by me. i'm only kidding, i'm too poor to be fast.
248/240 - you read all that crap just to get to here so here it is. coming from 240/240 in a nearly stock automatic car, i'm very disapointed. the only major difference is a slight gain in top end, maybe 2hp, but the loss of low end is noticable. i'd rather have that
240/232 - this is what i just put in my automatic car. im a huge fan of the low end here, and its better than 240/240. the overlap is always off by about 2 degrees or so when you use an intake cam used as an exhaust cam or vice-versa. So for that reason, 240/232 works very nice. i can tell it doesnt have quite as much pull in the top end as 248/232 but its part-throttle driveability is great. you really only feel the
240/232 - is great for a dailydriver, where low end torque is favored over top end merging power. in the automatic, after shifts the car has noticably more power than it does with 248/232. I would say if you have an automatic get the 240/232 because you spend more time in the midrange becasue of your gearing.
248/232 - is for the manuel car. ive gone to and from this cam swap in both
248/248 - is something im going to look at again with my current setup on the manuel car. (redrilled cam gear, intake manifold, SAFC, 3in exhaust, and dc sports header) it doesnt do any good in the
please reply any comments you want to about how your cam setup feels and drives through out all RPMs.
248 - S13 exhaust
240 - S13 Intake
car
, but i did install it on a friends automatic, and it did net similar results to my manuel car so i feel it's semi-fair to compare248/248 - is by far my least favorite cam swap. there is a noticable loss in low end, and the motor never rev's high enough to take too much advantage of the additional top end power. I'm not saying the top end isn't there, it just really only starts pulling until right before 6000 rpm, and pulls to 7000. then you hit the rev limiter and crave for a few more revs. maybe an automatic ecu and 7200 rpm mighyt be beneficial, but i love to rev it out and i shouldnt be allowed to have
200
more rpm. if i had a more top end oriented motor 248/248 would be a great thing to have, but until i can afford it, i wont ever use it again. the sound you get from this beast is nice though240/248 is obviously stock, its been a while since ive actually had a car with 240/248. but from what i remember the low end is decent but it does fall on its face in the top end. the 248 exhaust cam is trying to make top end
power
, but the 240 intake cam is trying to provide more all-around power, not just low or top end. i dont like it because of how bad it falls on its face before even 6500232/232 - i never tried, but i got em so i could.... but come on 232/232?
tires
into second gear in the automatic, granted its gotta be wet outside... anywho, 240/240 is what i'm directly compareing to 248/240 here. 240/240 has a nice pull even in the top end, and power is quite prominent in the 4000 rpm area. i'm still a big fan of 240/240 and i'd like to try it on my manuel car, but that car already has the hands down best stock cam swap possible....248/232 - this is hand-down where its at. If you have some s13 cams and some s14 cams you should have already done this. the power production is great everywhere. you only lose a little bit of top end over 248/248 and you gain more low end than you get with any other swap besides maybe 232/232. the KA craves this swap, it loves the low end and, chances are you only rev to 6500 anyway, so thats why this is the cam sawp for you. only don't do this if you wanna get beat by me. i'm only kidding, i'm too poor to be fast.
torque
back for this daily driver than the slight bump i got in top end. granted this car is actually proven quicker now than the 240/240 car, but its less satisfying. everyone wants to be put into the back of their seat right away, not eventually.....240/232 - this is what i just put in my automatic car. im a huge fan of the low end here, and its better than 240/240. the overlap is always off by about 2 degrees or so when you use an intake cam used as an exhaust cam or vice-versa. So for that reason, 240/232 works very nice. i can tell it doesnt have quite as much pull in the top end as 248/232 but its part-throttle driveability is great. you really only feel the
lowendtorque
when you are at part-throttle anyways, so you need ot make a decision....240/232 - is great for a dailydriver, where low end torque is favored over top end merging power. in the automatic, after shifts the car has noticably more power than it does with 248/232. I would say if you have an automatic get the 240/232 because you spend more time in the midrange becasue of your gearing.
cars
at least five or six times, and i always come back. its the best there is, and its greater than stock. its ideal for forced induction, and its cheap to do. i can imagine this swap would be even more devestating with a redrilled cam gear.248/248 - is something im going to look at again with my current setup on the manuel car. (redrilled cam gear, intake manifold, SAFC, 3in exhaust, and dc sports header) it doesnt do any good in the
auto
, the loss in mid and low end isnt worth it. ive seen a dyno of 248/232 vs 248/248 and the difference in top end is something like 2hp, but the difference in midrange is 6 peak hp and all kinds of torque.....please reply any comments you want to about how your cam setup feels and drives through out all RPMs.
They just swapped it over. moved the cam 3 or 4 teeth to get it to run and called it even.
I do seem to recall it being address though, that the results would be much better/different with an adjustable cam gear.
sounds sketchy making your own but shit.......... saves you the 150 you know?
how about buying cams that were designed for the app, not *** rigging shit....
like a 150$ cam gear.. buy a used matching pair of after market cams if your trying to save money
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
Boats N' Hoes
Nissan/Infiniti Tech
13
Apr 17, 2007 06:39 PM
bottlefed93
Dec 11, 2006 03:15 PM
