- Desperately need help 01 Civic idles at 4k rpms
- 91 Accord Crank pulley broke, need to know where to get new one
- Mishimoto Intercoolers?
- Ls ecu question. Need help
- 07 Acura TL Navi up date?
- Help lower my car
- i need some help guys
- 1991 Honda Accord Power Steering Issues
- wtb honda civic from lip
- !!!cash in hand help tr need to swap out my trany!!!!!!!!
- vtec question....
- honda accord 98 cooling system problems HELPP
- turnin on problemss accord 98
- da integra not starting. need help.
- Car shut off while driving need help
- Will eg a/c fit in an ek?
- acl main and rods bearings question
- my car. always stays cold need help.
- so what gen preludes are the best?
- Need help with integra
- Ebay Turbo?
- Ground problem
- Cable To Hydro ConVersion...Yes Or No Question
- 5speed swap
- Need help asap!!
- 1991 Honda Accord EX
- Wiring , wire and brake tuck questions
- Shifting/tranny problem
- Where to buy motors locally?
- NEED HELP-D16y8
- Break up after 3500rpm/crx swaped d16z6!
- gsr tranny help
- Rods and main bearings question. heeeeeeellllllp
- 98 Prelude - Immobilizer Help!
- mini me -d15 w/y7 head
- DA Headlight Help!!!!!!
- Need help asap need info.i got a b18b1 and it had a cable tranny read!!!!
- need help with my exhaust...
- Finding a exhuast for my sedan!
- out of control idle
- Problem with 99 Civic LX sedan
- need help integra running bad times
- D16Z6 Not gettiong Spark on 2 Cyl?
- Need a quick street tune
- 91 Accord Wagon Rotor Over Hub Help
- d16y8 head
- Mini me or the Z6?
- Rebuilding my first motor and i got questions
- Any honda exp want to make extra dollars? (brandon)
- VTec gets cold??
- NEEDS 98 civic 2 door door panels and interior accesories.
- Replacing carpet?
- Clutch noise.......
- 97 civic with weird acting battery light
- need help please. TPS replaced but throttle still on/off. revs also fluctuate at low
- p28 chip
- GSR knocking problem heeeelllllllpppp
- need honda expert mechanic for a valve adjustment
- po6 chiped, o2 pinouts for 4 wire
- Clutch cable breaking through grommets
- 89 civic brake problems/// stiff brakes!!
- tail light help!!!! on 96 accord
- Tranny problem ??????
- Brake up grade and/or 5 lug swap
- what do i need to make my single cam non vtec a vtec?
- accords springs
- Jdm gsr sputters
- Car screeches like a dirty whore when ac is on
- ls motor rear main seal
- Need mobile Honda mechanic for easy fix.... car located in Clearwater.
