No Spark....ideas?
Old Nov 25, 2010 | 08:36 AM
I-NEED-VTEC's Avatar
I have NO vtec!!!
Default No Spark....ideas?
Can't seem to figure out why I have no spark...Dist. is good...Main Relay (I have a back up) clicks when turning over, BOTH do actually...
Idk what it could be...Any ideas?
Rep for help..
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
Old Nov 25, 2010 | 08:39 AM
flatrex's Avatar
crx hatch sedan
Icm?
Old Nov 25, 2010 | 10:42 AM
boogieman2188's Avatar
Ignition coil?
Old Nov 25, 2010 | 11:24 AM
BoostedRacerDad's Avatar
Pops
What makes you think dizzy is good? Does it work on another car?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Nov 25, 2010 | 12:26 PM
Santos's Avatar
+1, also check all grounds you never know, also all conections leading to the dizzy.
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old Nov 25, 2010 | 12:34 PM
integra's Avatar
90% grind 10% sleep
+1 Pops....
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Dec 4, 2010 | 04:34 PM
I have NO vtec!!!
Ok, Thanks everyone for the input..
I am getting spark now, it's just not starting.
I am going to rotate the engine 180 and try that. I was told to remove the timing belt, keep the cam/dizzy on #1 pos. and bring bottom end to 280 put belt back on then it should fire up fine...?
Does this sound right?
I am repping everyone that has posted in here...
Thanks again guys.
Old Dec 5, 2010 | 06:47 AM
MotoX's Avatar
Master Tech
did you change the tbelt?
if you didnt mess with it, there is no reason it should be 180 degrees out
Old Dec 5, 2010 | 04:07 PM
I have NO vtec!!!
That's the thing, I've never touched the Tbelt...I checked it today, when I had the crank at TDC the Camshaft was where it should be. I then took off the dizzy cap and the rotor was facing #1, where it should be....WTH!??...LOL...I was told it could be the EGR valve or a vacuum line is not on...
I'm sure it's something Simple and right in front of my face...
Old Dec 5, 2010 | 06:18 PM
MotoX's Avatar
Master Tech
check for injector pulse
if you have spark and fuel to the rail
engine is in time
its the only thing left to check
