No Spark....ideas?
Old Dec 5, 2010 | 06:25 PM
I-NEED-VTEC's Avatar
I have NO vtec!!!
How do I do that?
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
Old Dec 5, 2010 | 07:35 PM
Santos's Avatar
Main Relay? what does it do when u turn the key to crank it?
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old Dec 5, 2010 | 07:45 PM
I have NO vtec!!!
It clicks like it's supposed to..
Once when you turn the key to the on position, then twice when you go to start it..
Old Dec 6, 2010 | 05:53 AM
MotoX's Avatar
Master Tech
when you turn the key to the on position, both wires going to the injectors should be 12+, when you crank, one remains 12+ and the other should pulse ground
Old Dec 6, 2010 | 08:23 AM
I have NO vtec!!!
Ok cool, I'm going to check that when I get home from work... Also, the "ICM" that the box on the pass side against the firewall right? I don't have one of them...and being that I swapped out the Y7 manifold for the Y8 I need to have one right?
One more thing that happened to, I used my buddies battery yesterday to start mine and the ground from the chassie to the transmission fried the coating around the wire, wth caused that?
I am a re re when it comes to this crap...
Old Dec 6, 2010 | 02:47 PM
flatrex's Avatar
crx hatch sedan
Icm is in the distributor......you getting any codes?
Old Dec 6, 2010 | 03:08 PM
  #17 (permalink)
I have NO vtec!!!
Oh!!!...yeah, the icm..(brain fart)...I changed it out with another to see if that was the case....I'll change it back to see...
Old Dec 7, 2010 | 06:27 PM
  #18 (permalink)
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
also, you said you chnanged the intake mani...make sure the ground at the t stat housing is tight.....
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Dec 7, 2010 | 06:51 PM
  #19 (permalink)
I have NO vtec!!!
Yeah, I put the Y8 I.M. on, I checked the T-Stat ground, it Tight...
How about the Chassis to Tranny ground FIRED when I went to crank it the other day, any ideas on that?
Old Dec 9, 2010 | 06:47 PM
  #20 (permalink)
PeteStop's Avatar
We can build your dream!
If you have spark just shoot some carb cleaner in the intake, if it pops off you have a fuel issue, it is pretty simple, if it fires off when you do that shared_pm me and ill take you step by step to get ya on the road!
PETE STOP
3991 Park Blvd
Pinellas Park, FL 33781
www.Petestopmotorco.com
PERFORMANCE, INSTALLATION,REPAIR,Nitrous fills, Mon-Fri 9-6 Sat 9-5
Complete Repair, Import,Domestic
Forced Induction, Bolt on, custom, alcohol, Nos
COMPLETE INTERIOR, Custom everything
Import tuning by, Carter Taliaferro
Domestic tuning by, Pete Stop- tuner of your choice.
If your not first your last!
727-541-3400
