da integra shutting off when hot???
a guy i know has a 1990 ls integra, it starts right up and runs fine until it gets hot and then it shuts off and wont run again til the car is cooled down, he also said it throwing a tps and map code. He has replaced the dizzy already. Any body had the same problem or know whats causing it? any help is greatly appreciated
its overheating... 4 cuases ...head gasket/water pump/radiator/thermostat
if this has happen mutliple time most likey his headgasket is gone.
check radiator for oil or check your oil to see if its milky
try swapping the main relay under the driver side dash
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
My money is on the Igniter inside the distributor...they tend to shut the car off once it gets warm and then you have to wait for it to cool down before it will start the car again. I know he said he tried a different distributor but that doesn't mean the other one was good either. These commonly go bad.
mine is on the igniter too but he said he replaced the dizzy...so replace the main relay...
CTR PARTS & PERFORMANCE in Tampa and in New York
83 Rx-7 GS 11.80@1/4 (wrecked it)
83 Rx-7 GSL 10.50@ 1/4 (blew it up)
93 Eg Hatch w/nos 7.50@1/8 (ex wife took it)
94 Eg coupe 9.50@1/8 (re-poed cause of babymama)
99 ek sedan 11.32@1/8 (totaled it)
99 odyssey van (lowered on 19s)
+1 i had that happen b4 aswell
says he replaced the dizzy. that doesnt mean he replaced the whole setup. He could have just replaced the housing which would only take care of sensors and not any coil/ ICM issues.
I would try replacing the ICM (ignitor) before moving on to the MFR...WARNING! Stay away from the Autozone/Advanced ones..I had an issue w/ my DA and used one of thiers since the OEM was out of my budget..I replaced it 8x's under the one yr warranty!
It left me stuck that many times and even costed me a few bucks in towing fees!
...TR's OldSkool DA Crew Member #00...
...TR's Oldskool DB Crew Member #02...
^+1 on bad Advanced Auto Dizzy
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
i actually bought the car from him cuz he needed some cash and he made a price i couldnt turn down. i believe its the icm also, i am gonna pull the dizzy cap and see if the internals are new also. i will keep you guys posted and i appreciate all the help fellas
