da integra shutting off when hot???
Old Nov 18, 2010 | 03:20 PM
honda-kid88's Avatar
I looked at the oil today and there is a little bit of water in it, milky spots. I was told it probably is the head gasket but my question is, If the head gasket was bad wouldnt that make the car overheat? It will sit there at normal running temp for about 5 or 10 min before it shuts off. I've never had a car do anything like this so any help us greatly appreciated.
Old Nov 19, 2010 | 12:27 PM
anyone?
Old Nov 19, 2010 | 12:45 PM
CrXSibeast's Avatar
this happened to me 2 months ago, my car overheated after putting water into it, so i shut it off right away and checked my oil, i had very little milky spots and i knew then i blew a headgasket, make sure when u get ur headgasket changed get arp headstuds and make sure too shave the head just in case to see if u damaged the surface!
TR "Old Skool DA" Member #39 Crew
Old Nov 19, 2010 | 05:00 PM
integra's Avatar
90% grind 10% sleep
throwing codes for TPS and map...Try switching the plugs they might be mixed up.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Nov 21, 2010 | 08:16 AM
thats the thing that throws me off is my car doesnt over heat, it runs at normal temp for about 5 minutes or so then it just shuts off.
Old Nov 21, 2010 | 08:18 AM
i'll check them and see, i appreciate all the input guys
Old Nov 21, 2010 | 11:49 AM
  #17 (permalink)
sullivanracing06's Avatar
how about swapping the main relay under the drivers side of the dash?
that has allot of current running thru it and it GETS HOT AFTER THE CAR HAS BEEN RUNNING try it
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Nov 21, 2010 | 01:10 PM
  #18 (permalink)
alright i'll try that, should i stay away from the advanced auto ones?
Old Nov 21, 2010 | 04:59 PM
  #19 (permalink)
never buy a discount auto electrical parts..... go to a junk yard and try n find a oem one or buy one from acura, i used the shop discount and got a bnib OEM one from acura for 58.00
Sullivan Racing LLC
352-665-2496-Tom
Old Nov 21, 2010 | 05:18 PM
  #20 (permalink)
i might just sell it but if i keep it i'll try that out first. thanks for the help
