Looking for help, will pay labor.
I need poly bushings done on my front end (EK). I have the bushings, I do not have a press, nor the patience and time to really take apart my front end to replace everything. If you can't do it, maybe you can recommend a shop to do so. I can have my car towed to a location via flatbed if I need to. I will NOT leave my car at some random dudes house to be "worked on" considering the amount of money put into this. Also don't say you can do the job if you just think you can do it and have no real experience. Give me a price for your time doing the install.
so is it just the lower control arm ones and strut you need done?im off tomorrow i would not mind maken couple bucks
i love AUTOZONE
i love AUTOZONE
Ill be at my shop tomorrow.. can do it for $50 a side....
CTR PARTS & PERFORMANCE in Tampa and in New York
83 Rx-7 GS 11.80@1/4 (wrecked it)
83 Rx-7 GSL 10.50@ 1/4 (blew it up)
93 Eg Hatch w/nos 7.50@1/8 (ex wife took it)
94 Eg coupe 9.50@1/8 (re-poed cause of babymama)
99 ek sedan 11.32@1/8 (totaled it)
99 odyssey van (lowered on 19s)
I have a press and i have done this numerous times....LMK if your need my help.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
Heres a list of the ones I need done...
lower control arms
lower shock bushing
front swaybar
rack and pinion mount
front end link
tie rod and ball joint boots (not all that worried about)
lower control arms
lower shock bushing
front swaybar
front end link
Well good news is u don't need a press for any of thos...so if the car does not move i would be more then happy to come to u if. Ur in tampa area.i would do all them for 40$ if u like that offer let me know
i love AUTOZONE
i love AUTOZONE
the lower control arms dont need to be pressed or burnt out? I'm actually located in Spring Hill.
Yes i just burn them out when i do them makes it alot easier.cause the new ones just slide right in and don't use the garbage lube they give u.yta gotta use some nice high pressre grease its alot better.
i love AUTOZONE
i love AUTOZONE
