What Aftermarket Bearings Are Good?!
engine bearings?
i know a lot of people use ACL's in their engine builds, but i have always used brand new OEM bearings from honda. never had a problem making LOTS of power on motors and having them last 10+ yrs
RIP Tim. i miss you, buddy
I just bought some ALTROM main and connecting bearings...ne input on those...
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
see above post.
use the codes found on the block and crank to select your bearing colors. then, before you put it all together, check your tolerances. if theyre off, you can go thicker or thinner depending on whats needed.
