Need Help Asap Car Wont Start!!!!
Old Nov 12, 2010 | 09:32 PM
wabyeg6's Avatar
Exclamation Need Help Asap Car Wont Start!!!!
OK TR i have a serious problem n need help.
ok im gona try to explain the best way i can
i have a 92 civic cx hatch.
ever since i got it when i put the key in the ignition i have to leave the key in until i hear the fuel pump and the main relay...
its like a click brrrr(fuel pump on) click again..then i can start the car...
sometimes it takes minutes to do this and its irritating...if it doesnt make this noise car will not start
its not the fuel pump or the main relay they are NEW!
i was told tht it had a kill switch BUT i cannot find it n e where
if someone can plz help i need help asap
GALATIANS 2:20
Old Nov 13, 2010 | 12:24 AM
zhillz's Avatar
Porno Music Producer
ignition
Old Nov 13, 2010 | 06:49 AM
BoostedRacerDad's Avatar
Pops
Get one of these, brand new with manual trans is outrageous @$229. Automatic trans is only $79.
Autozone
Duralast/Ignition Switch Part Number:
LS880
Price:
$229.99
Application:
With manual transmission
Warranty:
Limited Lifetime
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Nov 13, 2010 | 07:03 AM
Pops
a bad ignition (electrical) switch : Symptoms
  1. If you start the car and the radio dosn't turn on, then wiggle the key and it turns on.
  2. Most often, the dash will go dark when the car stalls (no warning lights, no shift indicator, no electrical, except the horns.)
  3. The speedometer and tachometer drop momentarily and come back up.
  4. Car runs fine when key slightly held at start position.
  5. Car stalls then can be restart, then stalls after driving or idling.
  6. Once started the the car starts for a second and dies after letting off the key.
  7. In some cases, the ignition key is warmer than normal and the electrical switch is hot.
  8. On rare cases, all of the gauges go dark when in the ON position but if held between the on and start position they light up.
  9. On rare cases, if held between the on and start position the system check bulbs light up on the instrument panel.
  10. On severe cases, when the key turns to ON the usual clicks under the dash is not heard as well as the check system light but the horns work okay.
  11. In severe cases when the key turns to START nothing happens (no electrical) but the horns or brake lights work okay.
  12. How to confirm: When white and black/yellow wire on the ignition switch is shorted the car starts and run fine using the key. Doing this bypasses the electrical switch. (Do not attempt if you're not certain what this means.) See basic troubleshoot for a far safer method.
Above*: The end result of a pitted electrical portion of switch. In your case however not sure if is the electrical part of switch or the mechanical cylinder. Thats why you should look at doing both.
JoKie TuNinG
StricKlyMT
727-510-6301
Old Nov 14, 2010 | 06:32 AM
wabyeg6's Avatar
Guys I really do appreciate this I will go out today and check this out
Again guys thanks
GALATIANS 2:20
Old Nov 17, 2010 | 02:02 PM
wabyeg6's Avatar
The ignition swith had electricity we did some test on it and its fine.....its not giving had...it has electricity nut the fuel pump isn't giving out gas....anything guys my cars not starting
GALATIANS 2:20
Old Nov 17, 2010 | 04:27 PM
wabyeg6's Avatar
any one plz
GALATIANS 2:20
Old Nov 17, 2010 | 05:20 PM
integra's Avatar
90% grind 10% sleep
Autozone
LS880
Price:
$229.99
Application:
Warranty:
Limited Lifetime
You need this too buddy.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Nov 18, 2010 | 02:35 AM
rangcrx's Avatar
engine building &best
just install a push button start for 5$
i love AUTOZONE
