crank pulley removal when engine is out. HELP
Old Sep 20, 2010 | 08:41 PM
VIT0's Avatar
Default crank pulley removal when engine is out. HELP
so im disassembling this ls longblock. how do i remove the crank pulley? of course it just spins. lol. i just need some good methods of getting ths bastard off. im using general primitve tools. help me out.
ocala=
Old Sep 20, 2010 | 10:19 PM
FoxHondaRider's Avatar
Registered Hater
there is a special tool. Its a big open 5 or 6 point thats on the outside? that you can put a 17MM socket through the center so you hold the crank with the tool so it doesnt spin and loosen the 17MM crank pulley bolt. Super simple. Just google or ask around for a crank pulley holder.
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Sep 21, 2010 | 03:44 PM
HondaEatingTSi's Avatar
4G63 PWR
its a hexagon type tool that goes inside the crank pulley itself to hold the engine from turning over. if you cant find one a large chain wrench will do the trick as well but can damage the belt grooves on the crank pulley
Honda/Acura certified Technician
Lexus/Toyota certified Technician
ASE certified
1992 Eagle Talon TSi AWD sold
2003 Maxima SE
Old Sep 21, 2010 | 04:15 PM
custom240sx's Avatar
DC Crew Member #1
Or you can do as I do and most of them have came off just by putting a 1/2" drive breaker bar on it with the 3/4" or 19mm socket and smack the hell out of it with a hammer, usually breaks them loose. Impact guns work well too.
Old Sep 21, 2010 | 04:20 PM
Registered Hater
^ could that be harmful at all shocking the crank?
Old Sep 21, 2010 | 04:35 PM
DC Crew Member #1
Impact guns shock the crank and that's what a lot of people use. And I would like to add, the harshness of the combustion process probably puts more stress on it.
Old Sep 22, 2010 | 02:41 PM
Rogue's Avatar
Used Register
Here are a few types:
Amazon.com: Honda Harmonic Damper Crank Shaft Pulley Holder Tool: Home Improvement
Amazon.com: Powerbuilt 648796 Honda Crankcase Pulley Removal Tool: Home Improvement
I have one of the latter... works great. There's a reason 130 reviewers have given it 4½ stars out of 5.
Old Sep 23, 2010 | 07:42 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
i have the second ^ it's actually slightly too small.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Sep 23, 2010 | 10:54 AM
Gotin's Avatar
Sayien
Bolt the head back on w/ the timing belt. Tighten the belt. Stick something between the the cam gears (wraped in something that wont damange your head), so that the belt does not move. Remove the bolt w/ a breaker bar. This wil need 2 people. It is ghetto, and not recommended, but will work with limited tools.
-B.J.F-
Old Sep 23, 2010 | 01:15 PM
92 CiviC H/B's Avatar
-Proud Croatian-
if you don't have the head but you do have the flywheel still on there. bolt on the flywheel. put a torque wrench on the crank pulley nut and put a breaker bar on the flywheel bolt.you need 2 people for this tho. one person holds the breaker bar and another unbolts the nut with the torque wrench. I've personally done it like this a bunch of times.
.TR's OldSkool DA Crew Member #14.
