crank pulley removal when engine is out. HELP
Old Sep 23, 2010 | 05:58 PM
luvsracin87's Avatar
turbo hhhmmmm?
put the fly wheel on then put a screw driver through one of the bolt holes at about 2 o'clock and it will stop the crank from spinning.........make sure its a good screw driver not piece of crap or it will break
Steve: (813) 810.4146 <~ call or text
Old Sep 24, 2010 | 07:07 AM
thegoldenchild's Avatar
i usually take the oil pan out and stick a piece of wood in the crank. ive never damaged anything and done it alotttt of times
Old Sep 24, 2010 | 11:02 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
^ that's a good way to get dirt inside the engine.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Sep 25, 2010 | 04:44 AM
Rogue's Avatar
Used Register
Originally Posted by DC2_BoostKING
i have the second ^ it's actually slightly too small.
Yeah, some of the reviewers on Amazon say they wrap the tool with some duct tape to thicken it up a bit.
I'd say if you have the ~$50, get the Honda tool, then you only need one breaker bar with a socket. I think someone I know has one of those tools, it's badass.
