Shaved/milled head question
I have a d16y8 head I want to shave/mill the head .030, I am wondering if an aftermarket cam (ex) crower stage 2 or 3 or a regrind delta will fit/have clearance issues? I am looking to upgrade the entire valve train port and polish etc. I have done lots of research Google search and forums and have figured thus far this would work with a stock valve train and stock cam. Any ideas??? Thanks
To me it sounds like the mill that you are doing on the head is normal, not sure about the deck on the block.
I would call the manufacturer, give them your specs and ask them.
Another idea is while you have everything out and apart before sending the head and block off would be to put the cams in then plastiguage to see where you are at and where you can go.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
2001 King Ranch F.150 (sold)
1991 5.0 Ls mustang (sold)
1993 ls cx hatch (traded)
1995 b16 eg coupe (SOLD)
2007 Hyundai Tiburon (sold)
2006 Yamaha R6 (sold)
1995 jdm b20b integra (sold)
2006 Mitsubishi fp red evo (dd)
I was thinking and would a Clay test be better for this to guage the distance between the valve and piston? We did a Clay test with my Single Cam build.
hi I'm Angela and you're welcome. I've learned a lot from my friend David. It's good to talk to an engine builder for stuff like this.
...91 SMF SCCA
