stripped spark plug threads
Old Nov 3, 2010 | 09:51 AM
sxysweed's Avatar
CRX.XXX
Default stripped spark plug threads
The spark plug threads in the head of my D15B7 are pretty much stripped. Getting the plug out was a PITA and it took some effort to get it back in. I want to pull it again and repair, it but I'm not sure how. Local shops have quoted me atleast $200 with the head on the car. And pulling the head is a no go.
I've read not to heli-coil it and to time-sert it instead. What's the better/best option?
Good method as to not drop a bunch of metal shavings in the cylinder?
Old Nov 3, 2010 | 10:06 AM
VenWood's Avatar
Take the head off. The time sert kit will cost you more than bringing it to a machine shop. If you can't do it yourself its probably cheaper to just replace the head. I'd just use the helicoil & not take the spark plug back out again.
Old Nov 3, 2010 | 11:03 AM
HonkeyDong's Avatar
Every dog has his day.
Replace head, single cams are dime a dozen
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Nov 3, 2010 | 11:36 AM
BoostedRacerDad's Avatar
Pops
^+1
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Nov 3, 2010 | 11:37 AM
YARO's Avatar
Smith & Wesson Protected.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Nov 3, 2010 | 12:08 PM
rangcrx's Avatar
engine building &best
replace the head like they said...you cant helicoil it or you will risk it melting or even falling down in the head when you change the plugs..you can retap it but not with the head on or else the shaveings will fall down in there..so no matter what you gotta take the head off
i love AUTOZONE
Old Nov 3, 2010 | 03:56 PM
HondaEatingTSi's Avatar
4G63 PWR
replace the head.
the time-sert will work but you have to pull the head to do that.
i have done quite a few oil pans that way. time-sert is just hondas recommended version of the helicoil,
Honda/Acura certified Technician
Lexus/Toyota certified Technician
ASE certified
1992 Eagle Talon TSi AWD sold
2003 Maxima SE
Old Nov 4, 2010 | 05:56 AM
jdm-az's Avatar
HPC tuned / DRAG CARTEL
the head is aluminum..... buy 3 new plugs. install each plug only once then removed it and throw it away. do the same with the other 2 new plugs and ur thread should be fixed. i just did this on a k-series swap and it worked fine..
oh and dont forget to put anti seize on it while ur doing it
Old Nov 4, 2010 | 06:32 AM
rangcrx's Avatar
i really hope this was posted as a joke,cause if not i would not post in any tech forum again,cause you will not be taken seriously,and if you did it to a Kseries i doubt anyone will ever let you touch there motor
i love AUTOZONE
Old Nov 4, 2010 | 05:26 PM
Paul2281's Avatar
I`ve done inserts with head on by putting grease on the end of the tap so it catch`s the shavings,worked for me several times.... And flush out the hole with break cleaner and compressed air ......But wouldn`t recommend it as your first time....Just buy a used head and be done with it like others have said...
Next time you install your plugs put a small dab of never seize on the threads....
