Compression test!!!
on
Compression test!!!
did a compression test yesterday on a 1990 acura integra b18A1 with GSR pistons
cylinder 1 200 psi
cylinder 2 195 psi
cylinder 3 200 psi
cylinder 4 200 psi
is this good or bad????
cylinder 1 200 psi
cylinder 2 195 psi
cylinder 3 200 psi
cylinder 4 200 psi
TR "Old Skool DA" Member #39 Crew
that is fine.
TR"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
that should be fine for boost, Did you do the comp test at operating temp? If it is cold you will have wrong readings. I did some research and there is a guy with the same set-up as you and he got
#1 190 PSI
#2 195 PSI
#3 190 PSI
#4 195 PSI
#1 190 PSI
#2 195 PSI
#3 190 PSI
#4 195 PSI
