any ideas for setting rings
Old Sep 29, 2010 | 05:51 PM
DOHC TURBO's Avatar
Default any ideas for setting rings
I just built the motor cylinders 1,2, and 3 are good at 230psi but 4 isn't set its at 150 and is burning oil pretty bad the head gasket is good no mixing of fluids or leaks and new valve seals. So any ideas on how to seat are appreciated. I'm running 10w 30 conventional oil and it's got about 200 miles on the motor I've been beating it pretty hard but no luck
Old Sep 29, 2010 | 06:32 PM
poorboy44's Avatar
TR Balla Donor Supreme
regardless what most people will tell, rings are set within the first 30 seconds of starting the car... also, with that big of a difference in compression, I'd be willing to bet there's a bigger problem than just the rings not seating properly
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old Sep 29, 2010 | 06:50 PM
DOHC TURBO's Avatar
I had the valve seats done because of low compression the first go around and what could the " bigger" problems be?
Old Sep 29, 2010 | 06:58 PM
rangcrx's Avatar
engine building &best
if you had the valve seats recut then you might just need to let out the and adjust the valves for that cyl they maybe to close"tight" and opening to soon it may not be oil your burning it maybe unburned gas
i love AUTOZONE
Old Sep 29, 2010 | 07:38 PM
poorboy44's Avatar
could be a few things honestly... was this a fresh build? new rings, new pistons, ect...? whats the setup consist of?
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
Old Sep 30, 2010 | 10:52 AM
DOHC TURBO's Avatar
Yes it's new I adjusted the valves but maybe I messed up ill check tomorrow and its an lsv. GSR head b16 pistons Honda rings
