Compatibility between D series head gaskets
I need to know if all D series head gaskets are interchangeable between different blocks and heads.
I do know that they have different thicknesses that will vary your final compression ratio, but are there others that are stronger or weaker on different blocks?
To sum it up, I am rebuilding D16Y8, and I want to save some money by purchasing a cheaper D series head gasket than the Y8 one. Granted the Y8 is the thinnest, giving higher compression, does that really stack up in the end?
Thanks
Thanks
cheapest one i think you will find is the old Graphite ones from the Crx d16 they are like 20$ but damn you cant afford 34$ for a new one?
i love AUTOZONE
i love AUTOZONE
dude, seriously...its the matter of like 10.00..........please please for the love of God, get at the minimum a z6 head gasket..,.......dont get those pos compostite gaskets.........why dont you get on ebay......you want cheap??? entire top end gasket kit for like 47.00......cheap=unreliable in the long run...hope you have some good shoes, you'll need em
