Dc2 CEL question???
Old Oct 2, 2010 | 06:18 PM
HoTsAuCe91's Avatar
Default Dc2 CEL question???
Ok i did that paper clip method n turn the key on acc to see if code shows. An the (cel) stay steady on no flash or blinks at all...wat sign is this leading too?
EG Crew Member #23
Old Oct 2, 2010 | 08:11 PM
HoTsAuCe91's Avatar
Guess no one knows this problem then!!
EG Crew Member #23
Old Oct 2, 2010 | 09:49 PM
HoTsAuCe91's Avatar
Ttt
EG Crew Member #23
Old Oct 3, 2010 | 06:46 PM
mtber's Avatar
Look here
Your cel must be on, then you jump the service connector.
If your cel is not on, & you jump the service connector & the cel stays on that means there are no codes.
If the cel is on and you jump the service connector and nothing happens, this generally means the ecu is faulty.
Old Oct 3, 2010 | 08:28 PM
HoTsAuCe91's Avatar
Thats a good thing...
EG Crew Member #23
Old Oct 5, 2010 | 06:52 PM
01LatinVizionGSR's Avatar
If i'm not mistaking thats a code 1 and it means that the ecu is bad.
Old Oct 6, 2010 | 06:27 AM
mtber's Avatar
Incorrect. Read what I posted.
A code 1 is an o2 sensor code.
Old Oct 6, 2010 | 11:50 AM
HoTsAuCe91's Avatar
It never blinks at all
EG Crew Member #23
Old Oct 6, 2010 | 12:02 PM
mtber's Avatar
Originally Posted by mtber
Look here
Read my post very carefully.
Old Oct 6, 2010 | 11:06 PM
HoTsAuCe91's Avatar
Ttt
EG Crew Member #23
