Starting problem..
So what can be the matter with my hatch that it wont turn on like normal cars should lol.. It was fine till we did the LS swap... now gotta turn it on with a cable from battery to the starter,
any suggestions on whats wrong with it?
| Right hand drive |
| Right hand drive |
Honda/Acura Tech is that way ------------------>
U sure everythigs pluged in?check ur harness ground wire its the one that bolts to the thermostat houseing,
i love AUTOZONE
i love AUTOZONE
clutch safety switch
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
+1
Its way up on pedal. Jump the switch, I believe it is a Normally open contact. try starting it. If that doesnt do it post year and make so we can look thru schematics.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Jump the switch first, if that doesnt work...then pull the single wire off the starter solenoid and measure for 12 volts with the ignition switch cranked. I need year and make of car.
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
