Starting problem..
jump the switch
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
That's what I would do. just jump a wire from your start up signal wire from your ignition straight to your starter....
CTR PARTS & PERFORMANCE in Tampa and in New York
83 Rx-7 GS 11.80@1/4 (wrecked it)
83 Rx-7 GSL 10.50@ 1/4 (blew it up)
93 Eg Hatch w/nos 7.50@1/8 (ex wife took it)
94 Eg coupe 9.50@1/8 (re-poed cause of babymama)
99 ek sedan 11.32@1/8 (totaled it)
99 odyssey van (lowered on 19s)
You never said Sometimes it starts fine....Check for 12volts at the single wire to ground with ignition on Crank. If you do have 12volts then clutch safety switch is good and you need to replace the starter as the solenoid on the starter is going and the reason it starts with the wire is you are putting direct volts/amps from battery to your weak solenoid. My .02
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
