how to check piston compression
Old Nov 13, 2010 | 02:16 PM
jonns14's Avatar
Default how to check piston compression
need help i want to know if there is a way to check if your pistons are high or low compression without removing the head?
300zx n/a blown thenTRADED
S14 ka semi built TRADED
S13 coupe Sr20det STOLEN
EG9 z6-t(swapped)LS turbo(blew)b20 turbo(traded)
EG6 lsvtec(stolen)(installed b16 nitrous then stolen again)
EG9 grocery bagger family car ( cop owned)
EG coupe b16 fully built (traded)
JDM front teggy lsvtec built high boost fail
EG bucket #becauseracecar HIGH BOOST here we come!
Old Nov 13, 2010 | 03:58 PM
jonns14's Avatar
23 views no comment
Old Nov 13, 2010 | 04:01 PM
SuburbanNoize's Avatar
Cold Ass Honky
Do a compression test.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Nov 13, 2010 | 04:16 PM
jonns14's Avatar
ya but wont it be the same like i know ls are 180-200 and gsr is the same , am i wrong if so wats the compression for stock ls pistons and for gsr
Old Nov 13, 2010 | 08:34 PM
rangcrx's Avatar
engine building &best
What Motor Do You Have?if You Can Compression Test It I Will Tell You What Pistons Dome You Have
i love AUTOZONE
Old Nov 14, 2010 | 02:12 PM
jonns14's Avatar
i bought a ls vtec and was told it was high comp so wat should i get on the compression test if its high and if its low around wat will i get?
